Home > Help Needed / General Tech Chat > Urgent Info Needed
1380Turboman
Member #: 221
Urgently need to know the model number or numbers stamped on the turbo dizzy.
Please help asap.
Paul.
1380Turboman
Member #: 221
Can anyone please verify if this is the correct type of distributor that I need:
Dizzy with ignition module on. Numbers on ign. module: 84896 -->3988
Numbers on Dizzy: AUU 1533 2003 --> 42661A /189
Just checked one of my dizzys - Module nos. 84193 A 2985
Dizzy nos. 41976B 3285.
This is totally different to yours..........???? Though i'm not certain this is a Turbo unit ?
I'll go and check the other dizzys i have, and get back to you.
Phil. *smiley*
Edited by Turbo Phil on 25th Mar, 2004.
This is from a normal MG Metro, as i've just removed it from the engine.
Module - 84567B
Dizzy - 419758 3585
Phil. *smiley*
Ps. I'll go and search for some more and check them.
1380Turboman
Member #: 221
Hi Phil,
Thanks for helping mate.
I got my numbers from an article in the general chat section were someone had performed a number of tests on a mk 1 and mk2 dizzy. However, I am not sure if they are correct.
Would appreciate someone checking the dizzy on their engine.
Phil, could i get away with just fitting the std electronic ignition of a mg metro. I wold prefer to find a proper turbo type with the right curve though!
Thanks again for the info so far!
Paul.
Gibbo
Member #: 34
The above question has been asked a few times now.
Does anyone have the advance curve for the Turbo dizzy?
I am running a standard mini dizzy with points at the moment, and was hopeing to modify it once the engine is run in.
Would be nice to mod it myself though if I knew the standard curve.
One for the FAQ maybe if anyone knows!
** Edited due to Stella error **
Edited by Gibbo on 25th Mar, 2004.
