Home > For Sale > mini turbo engine (uprated)
mikes minis
Member #: 421
nr newark lincolnshire
Fast road mini turbo engine
I have for sale my mini turbo engine it has covered 2500 miles and was built 5 months ago and is in good working order. Ok then starting from the top the engine spec is
· Cylinder head - aprox stage 4, fully ported and flowed with tubed pushrod holes etc.
· Engine block over bored with 73.5 cast omega pistons, Steel centre main strap, power flow high capacity steel backed oil pump also all the water ways have been drilled and taped if you wish to dry deck at a later date.
· Crank M.E.D crankshaft, which has been de, stroked to 78.3 mm, ni tempered, cross drilled mains and big end journals, wedged, bladed and balanced.
· Rods balanced cooper s rods with up rated rod bolts.
· Valve train it has got a piper phase 2 turbo camshaft, adjustable cam belt drive set up, chilled iron cam follers, the correct double valve springs to suit camshaft and heavy duty alloy valve spring caps.
· Clutch a/p race/rally friction plate and an a/p grey competition pressure plate.
· Gearbox ok it is a reconditioned rod change, 4 synchro a+ box with strait cut close ratio gear set fitted, 1:1 strait cut transfer gears, evolution cross pin differential with a 2.95:1 final drive.
· Inlet/exhaust the inlet manifold is a standard metro turbo item with a turbo 1.3/4 s.u carburettor and a modified plenum for intercooler and dump valve. The exhaust is a metro t3 set up with a maniflo 2”down pipe
· Ignition system mega jolt distributor less system using ford edis set-up.
· General the engine will come with fuel pump, regulator, intercooler/oil cooler and piping. Wiring loom for e.c.u 4 core radiator, k&n filter ect All the stuff you will need to get it running in your car. The only thing missing is a t3 turbo!
Any questions call me (mike) on 01529 455699
£2500.
Turbo Tim
Member #: 177
Avon Park 2006 Class D Winner
Woburn Sands
why you selling
16V project underway
mikes minis
Member #: 421
i am selling my whole car. but mini seem to fech just as much with a 998 as the do with a turbo engine. thats why i am selling engine seprate. and i am selling my mini because i need something more usefull. like a focus.
by the way the engine has a 8:1 comp ratio and was 125bhp AT THE WHEELS on 13 p.s.i
