| Home > General Chat > i am a plank! | |||||||
9th May, 2006 at 12:47:08pm
having given away a really good 98 mini head to one of alexb mates the weekend who needed an engine quick
Site Admin 6295 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
9th May, 2006 at 01:10:15pm
sorry bud! i bet Charlie has a spare head you could have now.. give him a bell |
9th May, 2006 at 01:11:51pm
be easier to get the bolts out. wouldnt have to take the head off all being well.
9th May, 2006 at 05:02:41pm
Yep, some sharp drill bits will soon see them off, all you need then is a tap to tidy up the threads.
9th May, 2006 at 05:15:01pm
what is the tap thats needed? Crystal Sound Audio said:
9th May, 2006 at 05:18:47pm
As the guys say... Also remember, it's only thermostat bolts - so not overly critical aswell. Centre-pop then as central as can be, and run a small (1.5mm say) drill down the pop around 1/8" - keep checking that it's being drilled central. Then drill down with a 6.5mm drill. This will follow the lead of the smaller drill and stay central. You can then tickle a 5/16" UNC tap down there and you should regain the thread.
9th May, 2006 at 05:21:22pm
also if there is some of it still sticking out file it nice and flat so its easier to find the centre.
9th May, 2006 at 05:28:44pm
All sound advice from the lads, the only thing I would add is a dremel can be used to level up the sheared off exposed bit to help find the centre.
9th May, 2006 at 05:30:07pm
PS if you are stuck for imperial drills and taps, M8 metric is easier to get hold of and will do the job just as well. Tapping drill size 6.8mm, but 6.5mm will give a touch more thread to bite at.
