Home > Help Needed / General Tech Chat > More Questions
1380Turboman
Member #: 221
Tried fitting the breather on the flywheel housing but it foils the brake servo? Even tbh cant get it to fit? Are there smaller types available are should i just cut a chunk out and weld it up again?
Paul.
You can mod it to fit, i.e bend it. Or you can fit the later type servo breather which i believe is "kicked" to avoid the servo. Id just mod it to fit. Im going to be doing my timing cover by modding rather than spacing the fan.
Or cut it half way up the 'tube' with a hacksaw and use a short section of a metro top hose and a few jubilee clips to re-angle it...
saskinsturbo
Member #: 121
ive had to do this on mine i cut it and rewelded it at a 45deg angle i did have pipe conecting it together but i thought id tidy it up i did actually rub through a brake pipe on the servo easy fix but very unsafe
saskinsturbo
mini-marauder
Member #: 68
Coventry
late minis, 89ish on i think, have a kinked over filter to clear this. i have one on my 90 RSP. got it from DSN i think.
MM
Sooperdooperturbocooperexpertengineering!
