Home > General Chat > charger comp map reading....
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
When reading this compressor map for an Eaton M45 charger...
Do the lines represent just air flow or does it included boost?
There are two lines, but what sort of VE are they working on?
Alex
AlexF
Surely they represent boost as a result of the airflow, given the type of supercharger design it is?
The Eaton type superchargers are all positive displacement machines. I think they are spiral vane type rootes etc.
They have a very high volumetric efficiency. The two lines represent flow as a result of speed at 5 or 10 psi boost.
You will need to calculate your required airflow at your required boost, that will then give you a speed for the blower.
You will have to estimate lines for other than 5 or 10 psi boost.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
thats what I thought guys!
hmmm I wonder if they like 17k?!?!
AlexF
You can overspeed them to 18k, but watch that efficiency dissapear... Put another way - there is a reason the lines stop at 14k.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
thats good news dave!!
Its not for a mini btw....
its either trash one m45 or maybe fit two!
AlexF
well, they're cheap enough!!
I think the adiabatic efficiency is only 60%, ie 40% of the shaft power turns into heat.
But I think the volumetric efficiency is high.
I might be wrong though.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I have 4 already lol
I work in the right place some say...
Its an E34 540i I am considering for a larf!
AlexF
Have you still got that BM as well as everything else?
Bloody hell, you collect more shit than a 12 barrelled pack of Andrex......
HAHAHAHAHAHA ill have to remember that one
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
No the bimmer went when I got the Scooby.... which is great but I did like my boat!
I have tons of stuff and projects... ask jimster he's seen the pile!!
alex
AlexF
