Home > Help Needed / General Tech Chat > Anyone got pics of their megajolt installed?
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Anyone got any photos of how your megajolts fitted? Where have you fitted the module/coilpack etc?
thankyou *happy*
james
Kean
Member #: 341
aka T2clubby
South Staffs
Not a great pic but you get the idea.......
The coil pack is mounted on an aluminium plate over the clutch housing, and the eids is up on the bulkhead to the left, also on aluminium
hth
Anton
Member #: 764
Staffordshire
there are some in my jornal on finity but it's offline again atm
jamesfawcett
Member #: 218
Cool!! thats ok, ill do as T2 clubby as done wit hthe coilpack it seems like a good place there *happy*
im the same as t2clubby, but my coil pack is on my brace bar
Anton
Member #: 764
Staffordshire
http://www.minifinity.com/modules/v4bJourn...coil%20pack.JPG
http://www.minifinity.com/modules/v4bJourn...hed%20Pully.JPG
http://www.minifinity.com/modules/v4bJourn.../Anton/EDIS.JPG
jamesfawcett
Member #: 218
thankyou!!!
mounted mine...
jamesfawcett
Member #: 218
also i got a small pulley i needed because it was fouling my head, ended up finding one from an old 850cc engine if anyone ever needs to get one. Think it will make cooling better too but i might lose power from it
you want to put some aluminium around the module, it needs a heat sink otherwise it could overheat and die
aparently
jamesfawcett
Member #: 218
Wont that like stop the air flowing to it as much?
Would it be better if i spacered it out from the bulkhead a bit to let air behind it? What about if i stick a heatsink on it?
Ben H
Member #: 184
Melton Mowbray, Pie Country
A flat piece of aluminium on the back will act as a heat sink. I have mine just like yours is and it has been fine, but overheating failures are a known problem with the EDIS so it is better to make the effort if you want it to last.
http://www.twin-turbo.co.uk
jamesfawcett
Member #: 218
didnt want to risk anything so ive modified an old pc heatsink and attatched it to the back...
Kean
Member #: 341
aka T2clubby
South Staffs
On 22/05/2006 18:24:23 mini1071s said:
Neat! And look at T2 clubby's engine, drool! What a nice 'bay!
Thankyou very much m8 *happy*
Bit different to that now though, dirty great intercooler and pipes everywhere lol
jamesfawcett
Member #: 218
Polish your altenator T2clubby *tongue*
Kean
Member #: 341
aka T2clubby
South Staffs
lol, its on the list m8
Im hopefully not too far behind you guys now, ive built the Megasquirt, and got everything bar the crank sensor bracket to do the install.
Ive opted for one of these:
http://cgi.ebay.com/ebaymotors/Megasquirt-...sspagenameZWDVW
i know its cheating, but im rubbish with anything more complex than a 3 pin plug, plus at 70 canadian dollars it was nice and cheap :)
clubman_dan
Member #: 142
Winchester
how long did that take to arrive mate?
jamesfawcett
Member #: 218
on that diagram on the ebay page, the megajolt has conections for O2 sensors etc, does the mega jolt lite have these too? mine hasnt arrived yet :)
dan - ill tell you when it turns up! (a bit like window rubbers eh feebs!!! *wink* )
feebs - im not sure, presume so, but a route around on the picasso site should put you right.
