| Home > Help Needed / General Tech Chat > fuel pressure bouncing | |||||||
![]() 127 Posts Member #: 439 Advanced Member derbyshire |
20th May, 2006 at 08:57:07pm
i've just fitted a pressure gauge inline after my regulator because im havin some leaning off problems, and its fluctuaing, i;e its bouncing all the time, it does steady on normal un pressurised feed but as soon as you blow in to the regulator press feed it starts bouncing badly and you can hear the reg ticking and also feel the pressure fluctuate with your mouth, it kinda push and pulls when its doing it, any one else had this problem?, i've stripped the reg and its perfect, plus its only a year old, the fuel pump is a month old and the filter is new,
20th May, 2006 at 09:32:10pm
I'd try another regulator.
AlexF |
20th May, 2006 at 09:33:40pm
i know but there expensive and what would make it do this, everything appears to be fine
20th May, 2006 at 09:47:37pm
A customers of mine had a very similar problem and a new reg sorted it... I did investigate the old reg though.
AlexF |
20th May, 2006 at 10:12:27pm
yes its ticking with it, like a vibration, also you can feel it if you put your tongue on the boost feed, it kinda pushes and sucks, if you know what i mean, like you can feel the diagphram moving up and down
21st May, 2006 at 10:58:54am
It could be the diagphram in the reg is stretched. You can get a replacement diagphram for about £8.
21st May, 2006 at 11:15:29am
yeh could be, it did seem a bit sloppy tbh, when i was putting it back together, spose its the only thing it maybe could be, i get one and give it a try.
21st May, 2006 at 12:25:21pm
i had same problem happened on the way back from avon, the pressure went on off on off on off.... and so did the fuel pump noises. got a new regulator and it was ok Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
21st May, 2006 at 09:39:05pm
This happened to mine when i fitted a fuel pump from a big Jag. The pump was to high a pressure and stretched the diaphram in the reg so the fuel pressure was fluctuating. Changed reg and put standard Metty pump on, problem sorted.
24th May, 2006 at 08:00:33am
ordered a new diaphram, see how it goes this weekend, thanks all for the help
