Home > Help Needed / General Tech Chat > does size really matter???
bawbee
Member #: 191
Falkirk, Scotland.
I had intended fitting 13" wheels to my turbo project but have been reading recently about handling problems when this size of wheel is used. I have the standard metro vented discs etc fitted---will 12" wheels fit with these or does it have to 13". Are the handling problems so bad with the bigger size?? *tired*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
not if you set the suspension up to match...
all this 10" are best is non-sence IMO.
Alex
AlexF
evolotion
Member #: 83
Glasgow, Scotland
i had 13*6's on my mini and it handles miles beter than my mini on 12's. these had an offset sich that the wheel was very close to the body, would probably fit under standard plastic arches.
Im now runing 13*7's of the usual "stick em out as far as theyl go" mini ofset. and the handling can be rather interesting at times. even at low speeds(<10mph) over badly maintained roads!
I also agree about this 10's is best nonsence.
Denis O'Brien.
saskinsturbo
Member #: 121
ive found that my turbo handles best on 10"s it could be the suspension setups or the width of the wheels who knows i just love my 10"s cos it help my pull off
saskins turbo
stock suspension definately works best on 5-5.5" 10" wheels. I suspect it's because these are a lot more 'forgiving'.
optimise the suspension to suit either 10 or 13 and i'm sure there is little in it between the two...
turbo hogster
Member #: 178
stowmaket suffolk
ive found 13 's to be great especialy on the traction front and in the damp wet british weather, on 10's mine use light up to easialy thus no forward traction, bit embarrasing at the lights when racing milk floats!!!!!!! *tongue*
