Home > Help Needed / General Tech Chat > verto bolt torques
Any one any idea of the torque settings for the diaphragm to taper boss and diaphragm to flywheels bolts of the Verto clutch???
I have tightened the diaphragm to boss bolts to 50lbft and used a little loctite retainer. The diaphragm to flywheel bolts i have tightened to 40lbft.
I cant find any refference to these as the haynes book says replace the lot.
Any help apreciated
EDIT: Just found in the rover workshop manual the diaphragm to flywheel bolts are to be done up to 25NM. Hell thats not much, but easily rectified.
Edited by Sprocket on 24th May, 2006.
that figure sounds about right
any more torque and they are on the boarder line to strip the threads.
the stud lock will do its job!
