| Home > Help Needed / General Tech Chat > EDIS Sparkplugs | |||||||
567 Posts Member #: 102 Post Whore Pennsylvania USA |
26th May, 2006 at 01:31:31am
Hi
26th May, 2006 at 02:09:28am
any resistored plug thats the right heat range for your engine?? i.e. what you already had in there? turbo 16v k-series 11.9@118.9 :)
26th May, 2006 at 02:15:54am
OK Thanks for that. I wasn't sure. |
1171 Posts Member #: 107 Post Whore Sunny Sussex |
26th May, 2006 at 08:14:36am
mines a fresh build with a Msquirt, how to i find the heat range?
26th May, 2006 at 09:39:18am
A BRP7ES will be good enough to get it up and running.
26th May, 2006 at 10:18:52am
Which way round do the plug leads go, ie what number to what plug. |
26th May, 2006 at 10:44:09am
connect the coil pack in the way it is labled. 1 to 1, 2 to 2 etc. http://www.twin-turbo.co.uk
26th May, 2006 at 04:12:14pm
As in 1 to the one closest to the rad or the clutch |
26th May, 2006 at 04:21:09pm
rad
26th May, 2006 at 09:29:52pm
And then 2 3 4 to the clutch? |
26th May, 2006 at 09:52:29pm
yes |
26th May, 2006 at 11:58:21pm
Thanks. Sorry to sound stupid. Here is another one. On the EDIS 4 module which is pin 1 |
27th May, 2006 at 08:46:28am
Its the one with PIN 1 stamped next to it. http://www.twin-turbo.co.uk
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
27th May, 2006 at 12:22:14pm
And remember this is a wasted spark system so it doesn't matter if you swap around the leads on the plugs that share the same coil in the coil pack. |
27th May, 2006 at 01:25:20pm
On 27/05/2006 08:46:28 Ben H said:
Its the one with PIN 1 stamped next to it. Yeah I see it now. i was looking on the plug not the base. Thanks for all your help. |
