Home > Help Needed / General Tech Chat > Master Brake Cylinder.
bawbee
Member #: 191
Falkirk, Scotland.
Is the old "Tin-Can" type of master cylinder suitable for Metro 4-pot set up? I read somewhere that it is not up to the job-doesn't displace enough fluid? Anyone have any thoughts on this one? *tired*
Do the math.
[pi * (d^2)] / 4
I suspect the two smaller pistons in the 4pots are identical to the area of one 8.4" piston. If they are, the std 'tin can' will be fine....
billydude
Member #: 48
Leicester
I've had a mini with metro four pots and the cooper larger bean can master cylinder with no prob's *smiley*
