| Home > Help Needed / General Tech Chat > EDIS Plug Leads | |||||||
207 Posts Member #: 193 Senior Member Aylesbury |
27th May, 2006 at 04:01:52pm
I need some help, i am currently getting around to installing the megajolt system, however i have come across the problem that i don't know what plugs leads i require. I have sent links to what should be the coil pack if i have done it right. Can anyone shed some light onto this matter as this is all that i need to do now.
27th May, 2006 at 04:23:39pm
heres how mine look:
27th May, 2006 at 04:24:28pm
you might have to turn your head to the side... "Turbo's make torque, and torque makes fun"
27th May, 2006 at 04:29:41pm
Thanks for the fast reply, they are the type that i am after. Do you know what car they are from so that i can go down to Halfords or somewhere, just to get a set. I really want to get the car up and running this weekend.
27th May, 2006 at 05:49:32pm
mine are off a N reg i.3 escort there very long no longer a series, but still 1.3 turbo.
27th May, 2006 at 06:08:11pm
on the photobucket site near the bottom after you generate the codes, it says messages for forums etc, just copy the text and paste it in a post. |
29th May, 2006 at 11:55:56am
I have managed to get a set from halfords and the car started on the first turn of the key. I was amazed, i thought that i was going to have loads of problems.
