Home > Help Needed / General Tech Chat > Thread of heater tap bolts and clutch slave bolts?
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Does anyone know the thread of the heater tap bolts/studs?
also, i need two bolts that hold the clutch slave cylindre to its bracket. Not two two that screw into the clutch housing i have them too, but the ones that screw into the metal bracket, anyone know what thread they are? thankyou!
Heater tap is 1/4 UNF
Slave bracket bolts were (i thought) 3/8 UNC aswell. If not, they'll either be 3/8 UNF or M10.
andeh
Member #: 97
Near Daventry, midlands
3/8unf, checked it with a head stud, nut end.
