Home > Help Needed / General Tech Chat > oil cooler
nobbie
Member #: 162
is an oil cooler a must on a mini turbo unit?
There's been a fair bit of debate about this in the past.
I would say NO for general driving, as you rarely see high oil temps here. But when long journeys for miles down the motorway are taken, they can produce very high oil temps. So YES this is where an oil cooler is needed.
The Metro Turbo item also seems abit on the large side, so the best compromise is to fit a smaller item with a thermostat so the the oil flow only passes through the core when high temps are reached.
Phil. *smiley*
