Home > Help Needed / General Tech Chat > Gearbox.
Leadfoot
Member #: 781
I have a problem whit the gerbox i think.
I just put a difrent gearbox on the engine. I got the car to run. Was out driving Later that day. The day after i drove 15 min away form home to a friend, when i was going home i sudently stopped. The engine die. One of the spark pluggs was loos. The car started, but it houldent drive. I can put the car in all its gears and i hear some rubbing noice difrent sound in eatch gear, but the car is standing there. This is the first time i have stripped an engine and gerbox apart.
Since im mekanical challanged i dont know what im doing. The engine is out of the car and everything turns around. It looks and sound fine.
Can the drivechafts be mounted on the wrong sides?
it sounds to me like the flywheel has come loose!
dont start the engine anymore and sort this problem my friend PRONTO!
has one of the drive shafts poped out of one of the joints??
is
a clue???
Leadfoot
Member #: 781
can a drive shafts just poped out of its joint?
billydude
Member #: 48
Leicester
I've had a driveshaft snap on the outer cv joint and this causes no drive also
jamesfawcett
Member #: 218
Bingley, West Yorkshire
I remember you telling us about that on miniclassic years ago!! in a pot hole or something?
