Home > Technical Chat > IDA at high speed
ok you clever sods,
who can work out how much draw i will be getting over the tops of my IDA ram pipes at speeds of 100 mph, they are sticking out of the bonnet by nearly 6" so are not be sitting still air and will be seing some serious wind .
as i'm now suspecting the front engine to be underperforming.
more so now i'n hitting higher top speeds, as after almost every run on gas that sees + 120mph the front engine is fuelled up and running lik a pig . the rear is no bother at all,
words like, ALOT, TOO MUCH,and LOADS, are acceptable but only in the absence of some proper maths as i already know this,lol.
carl
Strikes me, that you know there is an issue, so why not make a deflector to throw the air over the ram pipes and experiment?
MaltaMini
Member #: 510
Malta
Once you know its LOTS, then you should go for an extra large ERA-style vent... but you probably need a different exhaust system for that, if you're still using chimneys!
I donated, but somehow didn't get the label! :(
yes dave you are correct , i have already made the mother of all scoops, the one i have had lying around for years ,[yes the big ugly flooker] but needs must so it has to go on for a trial.
and if it proves to work i will be getting a differeng ex man made up and a much prettier ram scoop thing made,
i just thought i pose a techie for those with too much time on there hands,lol.
carl
Edited by fastcarl on 1st Jun, 2006.
I've been thinking of a "heightened" ERA vent myself...
I'll be dynoing my car with bot a 45DCOE and a 46IDA- It'll be interesteing to see the difference..
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Doesnt the ERA scoop suck air out of the engine bay?
Alex
AlexF
vegar
Member #: 189
How much is the IDA sticking up of the bonnet??
www.shag.no
I am sure there is something mentioned on this subject in the yellow Vizard book.
Yes it is!
Vegards, get the dyno opperator to blow the cooler fan over the top of the carb for a moment and see waht happens to the power and CO.
carl
