Home > General Chat > where do i stand?
Mini_Andy
Member #: 432
removing my clutch today. and my brand new flywheel puller centre bolt snapped.
it was only me using it so no excessive force was being used.
this has left me with the bolt in the clutch with no head on it :(
i have had the tool 6 days and this was the first time i used it. i got it from a well known mini supplier.
will this leave me with the job of removing the gearbox etc etc to remove it? or do i have the right to complain?
Many thanks
A poor and dis-heartened Andy
nogin
Member #: 487
westbury, wiltshire
if the tool breakes that was intended for the job then it is at fault, get a refund or a new one
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
minimole
Member #: 691
I broke 3 flywheel pullers trying to remove one of my flywheels they replaced everyone
Edited by minimole on 1st Jun, 2006.
Carl
Member #: 95
liverpool-on-sea
how has the center bolt stuck in the clutch? it doesnt screw into anything? it should have a washer on it that buts up onto the crank not screws into it. thats if im thinking of the right bolt.*indifferent*
jamesfawcett
Member #: 218
Bingley, West Yorkshire
I have a spare flywheel puller with a missing bolt if you want it i will post you it free. Its the same as my other one and the bolt i have works in both.
andeh
Member #: 97
Near Daventry, midlands
take it back striaght away, its not even worth thinking about. Some of the pullers sold by the shops are made out of crudite and are not up to the job.
Mini_Andy
Member #: 432
oops, i fucked up coz of lack of instructions.... still snapped 2 easy thoe.
my bad
jamesfawcett
Member #: 218
Want this one? Ill post u it!
my bad
mate, you havent forced the actual puller bolt down the crank thread have you?
if so thats why it will have seized and snapped, and if the threads kaput, then it might be new crank time :(
Mini_Andy
Member #: 432
can tell the glass is always half empty with you.
i aint been the first and i doubt ill be the last
sorry, just trying to help
