| Home > Help Needed / General Tech Chat > My bleed valve (pics) | |||||||
5th Jun, 2006 at 11:52:43am
my bleed valve has three legs, i bought it 2nd hand and this is it...
Edited by jamesfawcett on 5th Jun, 2006. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
5th Jun, 2006 at 02:32:12pm
as far as i know there are 2 ways to install a bleed valve (Dave will correct me!)
5th Jun, 2006 at 05:25:19pm
dont forget to fit a flow regulator inline feebs
5th Jun, 2006 at 08:59:48pm
I dont have a pipe coming out of my turbo tho Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
5th Jun, 2006 at 09:01:48pm
Does this mean i have to set the boost on just the actuator arm? Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
5th Jun, 2006 at 09:52:23pm
On 05/06/2006 17:25:19 benross said:
dont forget to fit a flow regulator inline feebs this is to go in the signal line from the turbo side to the bleed valve well fit a fitting in the pressure side from the turbo
5th Jun, 2006 at 10:52:36pm
oh is that all the pipe that comes out of a T3 turbo does? Is it just the boost that the turbo is producing? does this mean i can just take this pressure from the plenum outlet? Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
5th Jun, 2006 at 11:05:42pm
Am i right in thinking that just under my air intake on my turbo, its something to do with that small round thing, dont know waht it is now the engines in but i think there was a screw there. Is that where there should be something? Look just under the air intake...
5th Jun, 2006 at 11:36:58pm
yes i think so, if your thinkinbg what im thinking, you need to get that screw out and find a pipe fitting that, and then link it to the actuator
5th Jun, 2006 at 11:54:08pm
Engines all in and all the pipes and engine steadys are on now so im going to have to do that the next time the engines out :(
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
7th Jun, 2006 at 12:10:55pm
i went round to jimmys last nigth and the only option i can see is to take the signal from the plenum to the actuator, does anyone see why this wouldent work as effectivly as it would from the compressor housing?
7th Jun, 2006 at 03:09:02pm
i have never tried it but it should work. the only possible problems could be fluctuating boost pressure due to a delayed reaction caused by the air between the turbo and plenum compressing. however as there is no intercooler this possible/theoretical problem should not occur.
7th Jun, 2006 at 05:06:21pm
shed, the pipe on the actuator atm goes to nowhere:) |
7th Jun, 2006 at 06:24:17pm
yeah nowhere at the moment.
7th Jun, 2006 at 09:16:53pm
jimmy dont block the other outlet on the actuator, it need to go to atmosphere so that the diaphragm can move. |
8th Jun, 2006 at 08:07:10am
i used the T3 actuator for several reasons.
8th Jun, 2006 at 08:22:17am
On 07/06/2006 12:10:55 pot_dan said:
i went round to jimmys last nigth and the only option i can see is to take the signal from the plenum to the actuator, does anyone see why this wouldent work as effectivly as it would from the compressor housing? This is infact the best place to take the signal from, especially if you have an intercooler. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
