Home > Help Needed / General Tech Chat > Engine Paint
Anton
Member #: 764
Staffordshire
Is there any technial issues with different engine paint colours?
I'm tempted to paint my gearbox and transfercase black... any thoughts?
Anton
andeh
Member #: 97
Near Daventry, midlands
other than painting it pink or white, i dont see any probs? Anything on your mind?
Spam paints his engine transmission parts black IIRC
Edited by andeh on 5th Jun, 2006.
andeh
Member #: 97
From Miniresource, gaz's engine
http://img.photobucket.com/albums/v519/mod...gaz-engine2.jpg
dont use fancy engine paint that costs a fortune!
just use normal house hold gloss
2 coats let it dry a day between coats
i seem to get better results using the jelly paint for some reason ?
make sure the its de greased well !
if you want the ultimate finish
use red oxide paint as a prima first then 2 coats as mentioned above
good luck lets have some pics when finished
Anton
Member #: 764
Staffordshire
cool cheers guys... wheres that black paint then...
*wanders off looking aimlessly*
I didn't think it was a good idea to paint the gearbox in anything other than paint that contains aluminium. In my mind it will otherwise reduce the effective heat transfer resulting in hotter oil????.
Maybe not as much as i think though, but we use a special aluminium rich paint at work for stuff like that, keeps the heat transfer up, but we are talking large heat rejection areas rather than a small gearbox.
jamesfawcett
Member #: 218
Bingley, West Yorkshire
its harder to see where leaks are coming from on black gearboxes if its shiney
Edited by jamesfawcett on 5th Jun, 2006.
