Home > Help Needed / General Tech Chat > help - where do wires go??
pot_dan
Member #: 326
bradford, west yorks
i have had a go at the wiring, (used a second hand loom in vgc) and used haynes as best i can, but i am still unsure where some go to and from, also i will be using the elctronic ignition (just metro not megajolt) and need to know wich wires go to wich one on the module.
it doesent say in haynes wich colour wires go to wich conection on the starter and wich is positive and negative on the coil. i would really appriciate someone to go and have a look and note down as best they can for me? its mainly the ones to do with the starter/coil and dizzy i need help with.
thanks for any help. Dan i think the loom is from a 1984 onwards.
jamesfawcett
Member #: 218
Bingley, West Yorkshire
He means the three tiny plugs inside the electric dizzy connector, he doesnt have th eplug for it, so is going to use three tiny spade connectors to get it running.
Which of the 3 little prongs is live/earth and whatever else?
colas
Member #: 102
Pennsylvania USA
pin on the bottom of the ignition module goes to negative and the pin on the top to positive.
pot_dan
Member #: 326
thanks colas, when you say positive and negative is it just positive with ignition or + side of coil? does the middle do anything?
thanks. Dan
colas
Member #: 102
Pennsylvania USA
Positive and negtive markings on the coil.
