Home > Help Needed / General Tech Chat > Is this right? Coilpack on megajolt firing order.
jamesfawcett
Member #: 218
Bingley, West Yorkshire
two people have told me different things!!
first one said the coilpack has numbers 1,2,3,4, whcih it has.
He said connect these from left to right to each spark plug, so left cylinder to 1 on coilpack, next cylinder along to 2 on coilpack etc...
other person said connect them same as a mini, 1,3,4,2 according to the number on the coilpack, so 1 to the one on the right, then 3rd one in etc.
which is right? And will it be ok if i try the wrong way?
Want to start it tonite everythings ready but still waiting for my exhaust from someone.
No 1 cyl is water pump end. No 4 is flywheel end. Connect right cyls to numbers on coilpack.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
Tom is right, but as its wasted spark, it should be okay both ways.
jamesfawcett
Member #: 218
thankyou!!! just charging battery it was flat haha
colas
Member #: 102
Pennsylvania USA
Tom is right. But mine wouldnt run the other way. I put mine as the standard mini and it wouldnt start, changed them and it fired right up????
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
cyl 1 &4 are a pair
as are 2 & 3
If your not careful you wont get wasted spark... more mis-spark lol
alex
AlexF
Carl
Member #: 95
liverpool-on-sea
as has already been said above
coil pack________engine
1----------------------->> 1(waterpump end)
2 ---------------------->> 2(2nd from waterpump)
3 ---------------------->> 3(3rd from waterpump)
4----------------------->> 4(clutch end)
easy peesey*smiley*
Edited by Carl on 7th Jun, 2006.
jamesfawcett
Member #: 218
haha carl couldnt be clearer than that haha!!!
thankyou got it sorted but batterys still flat charging it overnight!
oh balls thats why its back-firing...
battery charge time..
Do I get points for using the search feature?
Edited by gr4h4m on 22nd Dec, 2008.
