| Home > Help Needed / General Tech Chat > stuck in gear:( | |||||||
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
10th Jun, 2006 at 01:21:58pm
i need some ideas please, i have only got the engine in the car about a month ago, i never seperated the engine and gearbox, but i did remove the diff housing and diff then bolted back on as it came off as far as i know. the engine came from a metro turbo and i cant remember too clearly but i am sure i put it in 3rd to nock the pins out...and thats where it looks like it is now on the selector in the mini...but it will not come out of gear now i have pulled verry hard and tried to swing the selector but it wont move, could it be something i missed when putting the diff back?
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
10th Jun, 2006 at 03:48:33pm
if you took the diff and side plateds off you might have disturbed the selector folks maybe, try taking off the side cover closest to the gear rods(right hand side) and see if you can move it then if nothing else works that is "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
11th Jun, 2006 at 08:11:34am
or you could have moved the selector shaft 180 deg whic will disnegaed it from the bell cranks with out you nowing, also another one is the bush in the reverse gear has moved out so the bell crank will move out of postion and locking it all up.
11th Jun, 2006 at 10:51:19am
i can get in to take the side plate off with the engine in cant i? i know i cant take the whole diff back off tho, it has to come back out. i cant remember what you can see with the side plate off or even the diff to think if i had disterbed anything, i dident pay much attention to the selector bit. will let you know how i get on..
