| Home > Help Needed / General Tech Chat > Head gasket opinions | |||||||
11th Jun, 2006 at 04:05:16pm
BOOM
11th Jun, 2006 at 04:13:33pm
I'd go down the 11stud route, especially seeing as the head is already drilled. Drop the head onto the block, nip a couple fo nuts down, then spot through the hole with a close fitting drill to get a centre point. Then remove the head, and seal up all the bores, water and oilways with tank tape or masking tape.
11th Jun, 2006 at 04:23:01pm
ouch bad luck fella, any damage to the block or head? On 15th May, 2009 TurboDave said:
11th Jun, 2006 at 04:27:25pm
One to add to the head gasket bar though....
11th Jun, 2006 at 04:42:28pm
no none at all fortunatley!! i did have a worrying thought that i might of done a fine impression of you and knackered my bores, but everything is fine
11th Jun, 2006 at 04:44:07pm
oh, and i got towed away by a certain young blonde steward who was there last year, not mentioning any names.... |
11th Jun, 2006 at 04:46:30pm
She tugged you off the race track did she sir? OOoo suits you sir....
11th Jun, 2006 at 04:58:51pm
i hope the apparent crap finish on the block where the gasket has blown is just debris, and not rusty corroded block face,.??.
11th Jun, 2006 at 05:02:01pm
I think its debris Carl, I know Nic's engine has only done a rolling road session and a track day since being run in from a new build.
11th Jun, 2006 at 05:02:09pm
yeah debris, it wiped off to spotless condition |
11th Jun, 2006 at 05:29:04pm
as tom says nic go the 2 extra stud route!
11th Jun, 2006 at 05:32:47pm
Mine is 3/8UNC both sides, this is the size of stud ARP supply.
11th Jun, 2006 at 05:41:14pm
Just 20 psi?
11th Jun, 2006 at 10:00:28pm
i have my old block that was 11 studded so i can use that for reference
12th Jun, 2006 at 12:56:26am
BE COOL ! .. nic................................................................................................................................................................................................................................................
12th Jun, 2006 at 07:32:12am
ive done this on my NA engine it was caused buy a big lean out at cruising speed and just melted the fire ring away and bllew it out. always looking for them bigger bunches of bannanas |
12th Jun, 2006 at 07:50:53am
This is exactly the problem we had, so we now have 11 studs, seemed fine at the weekend.
12th Jun, 2006 at 07:11:20pm
oh well at least it was now not at showdown. did you drive it there too. bummer. no longer a series, but still 1.3 turbo.
831 Posts Member #: 908 Post Whore gateshead |
12th Jun, 2006 at 08:57:28pm
mine went in the exact same position about 2 months ago. and strangely enough, i was putting about 17psi on it!!!!!!! balls to the blower!!!
12th Jun, 2006 at 10:23:22pm
Yep i blew 2 headgaskets in a s many days in the same place, aleit on the other side. Turned out to be a warped block... On 21st Jan, 2011 fastcarl said:
148 Posts Member #: 98 Advanced Member Slovenia |
13th Jun, 2006 at 07:49:27am
i had the same gasket problem last year. i do not know why? block and head were flat. it happened with 16psi. after changing gasket it never happened again.
15th Jun, 2006 at 05:16:44pm
On 12/06/2006 22:23:22 giallofly said:
Yep i blew 2 headgaskets in a s many days in the same place, aleit on the other side. Turned out to be a warped block... oh bugger, fingers crossed im confident it will be ok with the 2 extra studs back in, i dont know why, im just very very very hopeful |
