Home > 998cc > over heating
1976_mini
Member #: 259
grays, essex
Hi guys. My new little mayfair auto has been over heating loads lately. She runs really hot anyway, Bout 90-100 degrees. But lately shes been goin to 110-115. even on a run at 60mph on a dual carriage way. Ive changed the rad, changed the thermostat( even tried taking it out). I have a good flow of water when i take off the top hose.
Please help.
it may b small but it purfectly formed
http://photobucket.com/albums/v340/1976_mi...roject%20turbo/
Kean
Member #: 341
aka T2clubby
South Staffs
would I be correct in thinking the auto's have an oil cooler?
maybe its an oil problem as oppose to water?
1976_mini
Member #: 259
grays, essex
I dont think it has an oil cooler, not that i can see anyway. I changed the head gasget the other day as someone suggested that. He was right, all 4bores full of water, i couldn't believe it. But guess what? she still overheats, just not as bad now.
Ben H
Member #: 184
Melton Mowbray, Pie Country
Ok, so if you have changed the rad and you think it has OK flow it looks like it is an overheating problem not an under cooling problem. It could be a few things, to advanced ignition, running lean or all the water ways blocked up.
The increase in overheating could be explained by the increase in ambient of course.
http://www.twin-turbo.co.uk
1976_mini
Member #: 259
grays, essex
the ignition was advanced, but the mixture was ok. i adjusted the timing, but still no luck.
I think your right ben h, the water ways are blocked. given up now, time for a new engine.
thanks for the help anyway.
you did not mention that you changed the thermostat ??
this is the first coarse of action
at the last ditch atttempt try some of that engine coolent flush
1976_mini
Member #: 259
grays, essex
ive tried both benross. Nothing works
Se7en
Member #: 446
Burntwood Staffordshire
Headgasket?
