Home > Help Needed / General Tech Chat > Taking head off in situ
m4dn35s
Member #: 243
Portsmouth
Hi all,
Took turbo mini to beaulie yesterday and on way down it overheated got it home and was running fine but today when i moved it to fit an electric fan it was blowing lots of blue smoke!
I want to check that i haven't blown the headgasket or done anymore damage but dont really want to take the engine out!
Can i take the head off with the turbo with the engine still in the car?
Also what are the signs of a blown headgasket? as it runs ok and cant see any milky residue in the rocker cover or anything in the radiator!
Thanks Matt
WooHoo Passed it's MOT!!!! One of the cars in The Portsmouth Mini Turbo Massive!!
S1275GTt
Member #: 512
Basingstoke
compression test!
Ive done it with an SPi engine. Head, cast exhaust manifold, injection manifold, rockers and push rods all off in one.
Id expect it to be possible with the turbo, maybe a little more bulkier.
Nick
Member #: 154
Midlands
piece of piss with the turbo. unbolt the inlet and exhaust manifolds at the head, undo the top engine steady, wedge the engine forwards then balance the carb/inlet on the scuttle and slide the turbo off and rest it in the bulkhead box.
seriously its no different to an NA engine. half hour and you'll have the head off...
I think he means all in one as in with the turbo and carb still attatched. saves am exhaust gasket, perticularly if you dont have a spare one. It can also be a little quicker.
Dont know about the turbo though, the carb may catch the scuttle before the head is free of the head studs???
m4dn35s
Member #: 243
Portsmouth
ahh thats good, no just want to get the head off without taking engine out so im happy disconnecting the manifolds etc in the car just done want to take the engine out really!
Cheers matt
