Home > Help Needed / General Tech Chat > Rod change leaking!
Star Mag
Member #: 375
Leicestershire
Is there any way of stopping the rod change selector point on the gearbox as mine has quite a serious leak! Have change the small pound size seal but its made no difference. The only thing i have noticed is that i can get two of the seals into the casting, is there something missing.
The easy way to sort this is to fit "two" seals!*wink*
the first one the right way round full in and the second one the wrong way around to stop ingress of dirt.
make sure its free from oil and dirt using say white spirit after you have drained the oil
and then use some sealent around the out side of the seals befor fitment.
the above applies if the engine is in
if not engine is out, you would remove the diff cover and replace the inner ally locater with the small O ring and then a new seal
its a small kit available from minispares for around a fiver
oh! and do let the sealent set over night if poss before you refill it with oil.
this then will be put to bed
take your time and keep us posted *happy*
Carl
Member #: 95
liverpool-on-sea
might be worth trying this
http://www.minispares.com/Product.aspx?pid=35775
thats the seal kit which carl as posted
that would sort it but........
the engine needs to be out to do it easy!
of course you may...... do it in situe but its a right tow!!!!!
That's why you fit the small rubber gaiter :)
that helps as well vegard but... it only stops larger peices of debris
Possibly.. I'be used both the twin seal, and the Minispares kit with good results btw.
Stig
Member #: 694
Shropshire
The Mini Spares one worked for me. :)
Star Mag
Member #: 375
Leicestershire
Cool will have to get it sorted its leaking quite bad considering its only been done for about a month!! will just have to try again!! good excuse to change the oil!!
I've used that minispares kit,
the spacer make a real difference, stops the ear change moving about so oil can get out.
