Home > Help Needed / General Tech Chat > PDA for megajolt
jamesfawcett
Member #: 218
Bingley, West Yorkshire
What PDA works ok with a megajolt?
My navmans broken so im wanting a PDA that can run some GPS routing software and also the java program for megajolt.
will something like this be ideal...
http://cgi.ebay.co.uk/WOW-PALM-ZIRE-31-COL...1QQcmdZViewItem
Ben H
Member #: 184
Melton Mowbray, Pie Country
Don't know about the magajolt, but the megasquirt uses the Palm Vx. In the latest code you can used it as a dashboard, a datalogger and a full tuning tool. Very usefull.
http://www.twin-turbo.co.uk
jamesfawcett
Member #: 218
Is the megasquirt software also a java program? :)
jamesfawcett
Member #: 218
also do oyu have that photo of it attatched to your steering wheel i have searched for ages cant find it
Here you go
Ben H
Member #: 184
As far as I know the code is similar to visual basic. I have not coded in it, but a friend said it was easy.
I can't find the picture of it on the steering wheel either.
if you look on the megajolt webshite it says there
i think its somethink like a compaq that will do it, but im not sure about the new software that is being written, on will run off a game boy, but im not sure about the one done by 4600cc
jamesfawcett
Member #: 218
hahaha on a gameboy!!! that would look proper retro!!
Id be happy with just a basic black and white pda so ill have a good look on the megajolt site *happy*
Mike
Member #: 107
Sunny Sussex
i used an old palm for a while, but u can run it on a windows based PDA using StyleTap as a palm emulator http://www.styletap.com/
Anton
Member #: 764
Staffordshire
i belive the ipaq 2210 works with the megajolt
http://ipaqsparker.tripod.com/
jamesfawcett
Member #: 218
Do you know if the USB to serial port adapters from ebay will work with the megajolt ok? Ive just seen them so will be able to use the laptop
