Home > Help Needed / General Tech Chat > Revolution Sleeved Wheel Nuts
Anton
Member #: 764
Staffordshire
Anyone ever had issues with the sleeved nuts not soing thorugh the mounting holes on revo wheels?
Anton
no, but theyre are several lengths ive found
do you have too much paint on the wheels around the holes?
Anton
Member #: 764
Staffordshire
all sorted... it was paint mainly, but there seemed to be a ridge in the csting about 3/4 was down the hole which was stoping the nuts going though... an hour with a files has sorted it out tho... wheels look Sweeeeeeeeet.... i'll get some pics if your interested
Dangerous
Member #: 417
I had a problem getting locking wheel nuts long enough,(only holding by 2 threads)so modded them on a lathe
mra-minis.co.uk
Member #: 798
I invented dizzy blanking plugs
Midlands
Revolution wheel nuts also come in a couple of different diameters to fit Minis.
For 10's, 12's and some 13's they are the smaller type with a diameter of 0.5460in for a 33/64in hole and the larger 13's i.e. 7 & upwards use a 0.6765in for a 17.25mm hole... which equates to a 3/4in and 21mm sockets respectively.
Thanks
Kind Regards Martin
http://www.mra-minis.co.uk
