Home > Help Needed / General Tech Chat > gearbox trouble
nogin
Member #: 487
westbury, wiltshire
just need some help, just put engine in car luckely just box and block, i can select all gears eg can feel them engaging but cant get the box in neatural, eg engine always turning, when i select reverse it locks up, i did change the final drive before i put the engine in the car, have i messes the gear selecter shaft thingy up eg not lined it all up propperly, what do you think cheers
this is of coarse if any one can think of anything simple i have missed before i take the engine out again
Edited by nogin on 17th Jun, 2006.
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
well it could be clutch problems ?
or the box
remove the engine and go over your work again to identifie your error or error's
take you time and do it right
this is a pain but its got to be done
andeh
Member #: 97
Near Daventry, midlands
sounds to me like the selector could be mislodged against the outer part and is not properly disengaging gears when another is selected, hence locking up the box. u might be able to fix it by disconnecting the selector and using some pliers to align the set, might help if u have a second box next to you to work out whats going on. other than that its a engine out diff off job.
Unlucky dude :(
I always put the gearbox in gear when i've built it, usually reverse or 4th.
nogin
Member #: 487
westbury, wiltshire
well all apart, and have had a look at the box scratched my head for an hour, with another box next to me to look at, well for future referance it was 1st and 2nd syncro hub binding, lots of oil and a bar on the end of the first motion nut and it turns better now thank god for that, just got to put it all back in again
i also make things
turbo hogster
Member #: 178
stowmaket suffolk
before you get to carried away have you put oil in the box as the baulk rings will grab if not and will give you the cause of locking up but realy there is nothing wrong,
nogin
Member #: 487
westbury, wiltshire
it is the baulk rings as i can turn the box with a bar and a little bit with my hand which i could not before, so oil in the box it is cheers
i also make things
icklemini
Member #: 745
Northampton
Yep - Box was dry causing it to grab.
All sorted now??
Dave
