| Home > Help Needed / General Tech Chat > Actuator | |||||||
461 Posts Member #: 91 Senior Member Live @ Worksop, Work @ Rotherham |
18th Jun, 2006 at 01:13:38am
Would one of these be ok for a Mini running a t3, how easy are they to 'adjust'. I'm planning to run 12-15psi.
Edited by Dicanio on 18th Jun, 2006. |
18th Jun, 2006 at 11:39:34am
in short Yes
18th Jun, 2006 at 11:55:53am
Slightly off the topic, out of interest the actuator advertised on ebay states it's a -31 but what does -31 mean? , I've seen it on alot actuator (specifically T3 & T4) but I've no idea what it means. Isambard Kingdom Brunel said:
18th Jun, 2006 at 01:03:28pm
Thanks Benross, the actuator listed says that is adjustable, how easy will it be to adjust it or would it be better to set it and then bleed the signal off with a MBC to increase boost? |
18th Jun, 2006 at 01:21:25pm
i assume its adjustable by changing the springs?
18th Jun, 2006 at 02:14:22pm
they have different spring fitted
18th Jun, 2006 at 02:22:03pm
I think the -31 refers to the operating pressure in some funny measurement like inches of mercury,
18th Jun, 2006 at 10:35:06pm
Thanks guys, i think the best bet is to get an avonbar 8 psi actuator, that way i'll know exactly what i'm getting, then bleed off to achieve a higher boost. MBC or bleed valve though? |
18th Jun, 2006 at 10:47:18pm
i think the avonbar one may be the same as the collins one, it certainly looks very similar |
18th Jun, 2006 at 10:56:31pm
Yeh i agree, just working on the principle that avonbar will be a bit more knowledgable if i run into any problems |
18th Jun, 2006 at 11:34:56pm
true! and they seem a friendly bunch |
18th Jun, 2006 at 11:51:04pm
plus i might get a bit of TM discount |
