Home > Help Needed / General Tech Chat > t2 turbo, intercooler
welshdan
Member #: 1111
s wales
hi, my dad and myself are buliding a trbo engine for my mini this summer based on an mg metro block/box. we will be fitting a big valve head, kent 286 cam, a few other bits
was wondering how hard it would be to fit a t2 turbo? can it be made to fit by fabricating adaptor plates or does a whole new manifold have to be made
aslo, im looking at an intercooler. problem is fitting one in. was wondering what would be best to fit inder a round nose mini. am fitting a 10 row oil cooler at the front, leaving less space:(
my dad has built loads of good engines before, just not any with turbos, so any advice wold be appreciated
FAQ / search?
SumpNut
Member #: 28
Adaptor plates can be machined up to convert the fittings on the standard manifold.
Infact Jimster on this site sells them....
I am a big fan of the mirage setup, a complete set of exhaust manifolds designed for a T2 and no modifications to the bulkhead, Contact member Mirage on this site for more details.
Dan
(welcome to the forum by the way):)
as Turbo dave stated, exactley*wink*
its all here for you
the 286 cam for get it on a turbo motor
the oil cooler no more than 6 rows, is a waste of room and expence*wink*
It can be fitted with an adaptor plate but this will require a bulk head box to be fitted to clear the turbo. Or you can go down the custom manifold which alow you to fit a T2 without a bulkhead box out of the after market manifolds Mirage are the most well know and have a good rep.
In the front of the engine bay (sorry I couldn't resist)
