| Home > Technical Chat > Rear Turbo Weber 32/36 fuel curve sorted - dyno this week | |||||||
141 Posts Member #: 954 Advanced Member Fort Collins Colorado USA |
26th Jun, 2006 at 07:35:58am
Took some fiddling, but the Weber 32/36 now runs very well under boost. Narrow-band O2 sensor shows ~800mV under power. Took some doing to get the last flat spot out. I wound up shimming up the spring on the power valve to make it come in sooner and also stay on more under boost at part throttle.
1275 with Back Door Turbo |
26th Jun, 2006 at 07:28:43pm
cool, any pics of this setup? what mods are needed to the weber for turbo use? cheers |
27th Jun, 2006 at 04:07:28am
If you search for my username (fortfun), you'll find the previous threads that have photos. The only mods to the weber were to remove the choke linkage and seal off the hole with epoxy putty and to shim up the spring on the power valve. Other than that it was rejetting only. No obvious leaks around the throttle shafts. 1275 with Back Door Turbo |
