| Home > Help Needed / General Tech Chat > Metro Turbo Challenge fuel plumbing circuit ? | |||||||
26th Jun, 2006 at 09:32:06pm
i noticet gialloflys aka John flans metro Turbo challange car
26th Jun, 2006 at 09:37:47pm
i was considering the same mod Ben. Braided hose is very expensive and i already have a feed! |
26th Jun, 2006 at 11:00:29pm
I am certain it does have a return, i'm 100% certain infact that it returns fuel back to a swirl pot that the high pressure pump pulls from. there are then two inertia pumps lifting from the main tank into the said swirl pot.
26th Jun, 2006 at 11:34:14pm
Some of our turbo lot use a T piece on the feed to the fuel regulator as the return, often just a plastic T piece.
Edited by giallofly on 26th Jun, 2006. On 21st Jan, 2011 fastcarl said:
26th Jun, 2006 at 11:43:43pm
thanks john
27th Jun, 2006 at 06:30:39pm
theres loads of trick bits under jons bonnet, just little things that look cool.:cool: no longer a series, but still 1.3 turbo.
27th Jun, 2006 at 07:12:17pm
bugger completly wrong, Whats all the braided pipes running through the car if they are not fuel lines then mate? |
27th Jun, 2006 at 08:38:30pm
I was wrong to!
27th Jun, 2006 at 11:30:49pm
i'm using a platic T piece for my return line. it goes back intot he fuel feed inbetween the tank and pump. all it is is a plastic T thats rated @ 10bar. one of the types with the teeth that you push fit plastic pipe into, then i've jubileed my fuel pipes onto these plastic bits. Has been fine for the last 2 years...actually thinking about it, i might change my fuel filter before avon seeing as its been on since i turbo'd the car :$ On 20th Oct, 2015 Tom Fenton said:
28th Jun, 2006 at 02:18:08pm
right, instead of the fuel return line going back to tank.
28th Jun, 2006 at 02:37:06pm
If I have understood what you have said Ben then I don't think it will work.
28th Jun, 2006 at 02:44:35pm
On 27/06/2006 23:30:49 bud666 said:
i'm using a platic T piece for my return line. it goes back intot he fuel feed inbetween the tank and pump. :$ will- going on budds theory which works! this is the same buddy
28th Jun, 2006 at 02:51:04pm
Maybe I don't understand what you are saying then. Buds returns to the low-pressure side of the pump (essentially the tank) it still runs all the way back. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
28th Jun, 2006 at 04:24:59pm
Right wil_h you mean the Suction side of the pump.
