Home > Help Needed / General Tech Chat > Who sets their exhaust and inlet tappets to different values?
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Who was it that sets their exhaust and tappet values to different ammounts? Was it nic?
My feeler guages only show numbers like 0.003 or 0.020 etc, does anyone know which i should set each to?
Ive searched for ages but theres so many search results for tappets.
Ive ran the engine for quite a bit now so going to torque it again in the morning and set tapets again. When would you recomend to do it again? After 500 miles or so?
thankyou
James
i do but i never said it, i think it depends on the cam
ehat are you using?
i set mine to 0.15" inlet, 0.14" exhaust
but if your not sure then i usually use 0.15"
oh and i set mine at the start, then when run in, or whenever it starts getting rattly
Edited by Nic on 27th Jun, 2006.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I do - if the cam commands it!
AlexF
jamesfawcett
Member #: 218
mines the turbo one from morspeed ill find out which one today or actually i might ring them and ask them
