Home > Help Needed / General Tech Chat > tappet setting
1976 clubamn
Member #: 400
Shrewsbury
if using 1.5.1 rollers should i use the standard tappet clearences or different ones?
If it breaks... build a much faster one
std i believe
bit wider i thought?
1976 clubamn
Member #: 400
Shrewsbury
is there anyware i might be able to find out
Dangerous
Member #: 417
.003" to .005" bigger say's on here
http://www.minimania.com/ArticleV.cfm?DisplayID=110
Valve clearances should be opened up by 3 thou over recommended settings, although up to 5 thou can prove beneficial with certain combinations
Edited by Dangerous on 28th Jun, 2006.
1976 clubamn
Member #: 400
Shrewsbury
can you tell me what they should be in mm sorry to be a pain
Dangerous
Member #: 417
0.1mm =.004"
1" = 25.4 mm*tongue*
1976 clubamn
Member #: 400
Shrewsbury
cheers for that
themaninthesuitcase
Member #: 1124
Surrey
I was taught 10 thou times the ratio.
andeh
Member #: 97
Near Daventry, midlands
Give that man a pie, tappet clearance has to remain 10thou according to the book. however, since you are measuring it at the valve not the tappet, you have to set it relative to the rocker ratio. In otherwords 10thou * rocker ratio = valve clearance.
Edited by andeh on 28th Jun, 2006.
themaninthesuitcase
Member #: 1124
Surrey
think it was you who taught me that lesson *wink*
andeh
Member #: 97
And i think it was mr yardy who taught me, ooer *blush*
1976 clubamn
Member #: 400
Shrewsbury
so would i be right in thinking that 15 thou or 0.38mm is an ok clearence
andeh
Member #: 97
Its what i've always used with 1.5 rockers
1976 clubamn
Member #: 400
Shrewsbury
great, thanks for the help guys
