| Home > General Chat > Timing gear question | |||||||
28th Jun, 2006 at 10:29:13pm
Just thought i'd have a quick check over my cam timing before the RR, make sure its all in order and i know dots are everything but i thought they should be somewhere near?
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
28th Jun, 2006 at 10:33:47pm
The most i've ever seen dot's out by was one tooth 17deg, but then i've only timed in about 3-4cams using the proper method. Of course that only applies to fixed gears, not vernier type where the middle moves and can acount for more offset int he dots.
Edited by andeh on 28th Jun, 2006. I've seen the future and tbh its Pie
28th Jun, 2006 at 10:45:12pm
thats what i think but obviously anyone can make a simple mistake.
28th Jun, 2006 at 10:48:54pm
woah almost continued that post with a gay song reference, not sure what it is but i know my sister used to like them |
28th Jun, 2006 at 10:49:24pm
The dot on the large ring can be anywhere,depending on how it's bolted to the centre.
29th Jun, 2006 at 07:34:46am
Deffo worth checking just for piece of mind. Cam timing is easy to get wrong if you get distracted, and simon is always getting distracted by random idiots bothering him.
29th Jun, 2006 at 09:48:48am
Iain, you are welcome to use my magnetic stand,disc and vernier....wel worth checking. On 21st Jan, 2011 fastcarl said:
29th Jun, 2006 at 10:28:34am
if in doubt check...
AlexF |
461 Posts Member #: 91 Senior Member Live @ Worksop, Work @ Rotherham |
29th Jun, 2006 at 09:13:23pm
Iain, i've got magnetic stand and dial if it closer for you to collect. Offers there mate |
