| Home > Help Needed / General Tech Chat > sorry more questions | |||||||
2nd Apr, 2004 at 11:06:50pm
hi coming from my last post people have said i cant put the box lower but in the how to everyone suggests it eh? Also what is the easiest way to brace the car so none of the mounts move? can i cut the hole with the sub frame in? |
2nd Apr, 2004 at 11:23:14pm
a std box gave me enough room... normally its best to put it over to the right side of the engnie bay to clear the actuator better.
AlexF |
2nd Apr, 2004 at 11:53:49pm
I can't see why you need to really put the box any lower ?
3rd Apr, 2004 at 12:00:56am
cheers lads for the advice, when i got the box from avonbar they sent me a fact sheet saying it is important to brace the front end while the subframe is out so that the subframe mounting points do not move, thats why i wanted to keep the subframe in. |
3rd Apr, 2004 at 05:58:57pm
just booked mine in at a retro car garage. Its 29 pounds an hour, i need to get the dimensions for the box though. Does anyone have any? Or could anyone scan in the avonbar instructions? He says it will be easy stuff, also gonna cut the corner off. Gave him loads of print outs of you guys cars so cheers for that!
3rd Apr, 2004 at 07:41:06pm
just done my bulkhead this afternoon aswell, loads of pics of your cars across me windscreen for directions. didn't take long i used a plasma cutter instead of a grinder. i cant believe the box from minispares came with no instructions and only had 6 spot welds on it, ive had to seam weld the box aswell!
3rd Apr, 2004 at 08:49:04pm
i did my box with the subby in no probs no longer a series, but still 1.3 turbo.
3rd Apr, 2004 at 10:40:36pm
Yes it's really a good idea to seam weld it !
5th Apr, 2004 at 12:51:32pm
Yep, my box went in with the subby still in.
