| Home > Help Needed / General Tech Chat > is my crank buggered | |||||||
![]() 94 Posts Member #: 400 Advanced Member Shrewsbury |
30th Jun, 2006 at 06:41:26pm
i have just removed the clutch and flywheel, in preoration for fitting the new oil pump and found this
Edited by 1976 clubamn on 30th Jun, 2006. If it breaks... build a much faster one |
30th Jun, 2006 at 11:41:35pm
yes it looks like it but a better pic would be better to confirm things 100%
Edited by BENROSS on 30th Jun, 2006.
45 Posts Member #: 446 Member Burntwood Staffordshire |
1st Jul, 2006 at 12:35:51am
You Broke it.Make it faster :) |
1st Jul, 2006 at 12:44:54am
sorry about the photo, just worked out the macro setting on my camera, hopr this is better
1st Jul, 2006 at 12:46:56am
the boss is in pretty much the same condition, but i do have another If it breaks... build a much faster one |
1st Jul, 2006 at 01:11:03am
ouch o rama |
1st Jul, 2006 at 01:42:50am
yes we can safley say its JOSSED!
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
1st Jul, 2006 at 08:18:25am
The crank isnt completely toasted, i have seen worse come out from under a flywheel, but i dont think its worth saving finatially.
1st Jul, 2006 at 08:20:10am
If anyone buys an en8 lockplate from minispares that last sentance needs to be followed as i havent yet fitted one which doesnt need modding! I've seen the future and tbh its Pie
255 Posts Member #: 520 Senior Member nr hull |
1st Jul, 2006 at 08:52:31am
ouch! i had a similar thing happen to me a while back, the flywheel bolt came loose and the flywheel friction welded itself to the crank! it looked even worse that that! needless to say after a new crank and new u/l flywheel i make sure i put em on properly now!
doh! why did i start messing with it!
1st Jul, 2006 at 09:17:45am
On 01/07/2006 08:52:31 hippyinamini said:
needless to say after a new crank and new u/l flywheel i make sure i put em on properly now! steve sure most peeps have there theres no room for error here ! or any where come to that
831 Posts Member #: 908 Post Whore gateshead |
1st Jul, 2006 at 12:50:49pm
my mate had a flywheel that sheared the pullet trying to get it off. he used nearly a full can of wd40 on it then got another puller and left it tightened on overnight. next morning he went in his garage to find a f**k off great dent in his garage door and the flywheel sitting there.
balls to the blower!!!
1st Jul, 2006 at 01:56:24pm
hippyinamini i remember that on your brand new engine was gutted for you Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
2nd Jul, 2006 at 04:30:21pm
i have just pulled my flywheel off and guess what ??
3rd Jul, 2006 at 08:02:53pm
if i had fitted this clutch assembly then i wouldnt be so pissed, it as it would have been my fault.
3rd Jul, 2006 at 10:39:28pm
bah doublepostnightmare Edited by andeh on 3rd Jul, 2006. I've seen the future and tbh its Pie
3rd Jul, 2006 at 10:39:49pm
On 03/07/2006 20:02:53 1976 clubamn said:
but because it was suposed to have been fitted by a profesional i am we narked now that is truely anoying and i would be taking it back to get replacement parts at the very least. There is no doubt that that damage would have been caused by poor fitting. I've seen the future and tbh its Pie
