| Home > Help Needed / General Tech Chat > IDM wire on megajolt!! Megajolt not showing revs | |||||||
30th Jun, 2006 at 10:01:24pm
Just think ive solved the problem maybe, ive plugged the laptop and got the runtime display, and its showing 0 revs! the map sensor is working but no revs
255 Posts Member #: 520 Senior Member nr hull |
30th Jun, 2006 at 10:25:30pm
the jolt only needs 4 wires to make it run feebs, saw, pip, an earth and a 12v+ everything else is optional, you sure you have the saw and pip wires the right way, i got em mixed up due to a crap diagram i coppied onto some note paper and it had me puzzled for weeks..i had the same problems, it saw the MAP readout but rpm wasnt working.
doh! why did i start messing with it!
567 Posts Member #: 102 Post Whore Pennsylvania USA |
30th Jun, 2006 at 11:43:18pm
PIP and SAW are the only wires between the Megajolt and the EDIS unit. |
1st Jul, 2006 at 12:06:11pm
Hi steve yeah double checked the wires and theyre exactly the same as my diagram :(
