Home > Help Needed / General Tech Chat > what will i find? update 5/07
Carl
Member #: 95
liverpool-on-sea
not realy asking for help on this YET! just wondered if anyone would like to hazard a guess to what ill find.
at retro cars today i did me 1st run lots of wheel spin off start but a good run i think but on me second run when i got back to the end of the strip me steering felt very heavey and the car seemed to pull either way at random. when turning wheel left or right on the spot i get a creak type noise. when steering left right whilst driving i get the same sort of noise and a bit of a vibration. when on nearly full lock it squaks and creaks. when reversing on full lock feels like something is binding up. felt like driving a 4x4 with diff lock turned on.
so i jacked each front wheel up one buy one and in neutrel the wheels are very very diffecult to turn and whilst turning wheel and putting your hand on both the inner pot joints a you can feel the knocking/creaking is coming from there. i dont think both pot joint would have gone faulty at eacctly the same time. so im thinking a diff problem.
ive got a 900ish mile (at the most)old minisport 4 pin fitted that i bought new. it was the only diff i could get the time so do nt sa you told me so!!!
so ill strip it this week i rekon could be a bust diff or bearings, what do ya rekon?
Edited by Carl on 5th Jul, 2006.
your on the right track carl
if the cv joints and the steering, ball joints etc... check out 100%....... then go for that buddy
keep us posted
Oh! just a thought make sure all the ball bearings are fitted in the inner cv joins aswell
Carl
Member #: 95
liverpool-on-sea
right took me engine out and took diff off. diff and bearings both seem ok although diff feels a bit tight ill strip it another day.
found major problemo in the box tho*frown*
the 3 bolts that hold the bearing retainer on near f/d have pulld out of the casing. the bearing has moved out of the resess then this has been rubbing on the crown wheel. think this is me problem
so ill strip the box off tomorrow and strip it on wednesday and see what i need hopefully wont need much.*frown*
bizzare mate. hope you get it sorted in time for avon! *smiley*
dan
Member #: 93
strange one that carl, has anyone else had this happen before?
If you need a new case, I've plenty you can have.
Wil
Carl
Member #: 95
liverpool-on-sea
i think the bolts pulling out may have been my fault due to overtightening them. looks like the crown wheels probably been rubbing on it for a while*frown* cheers wil but i think ive got a spare casing.
oh and me diff is definatly knackered looked ok when id taken it out but felt a bit stiff. so i stripped it to pieces. bolloxed absolutly bolloxed. one of the shorter pins had worn and welded itself into the little pinion wheel. only affter less than 1000 miles *frown*
That sounds lousy.
Still - plenty of time to fix it!
turbo hogster
Member #: 178
stowmaket suffolk
yep mini sport diffs are crap minispares ones are the best but didnt help having the main bearing retainer coming out thou
That really is poor from Mini Sport, let us all know how you get on trying to get them to replace the knackered diff.....
doh and bugger!!
hope it all goes well getting it back together
