| Home > Help Needed / General Tech Chat > turbo boost discharge | |||||||
53 Posts Member #: 1013 Member OXFORD |
3rd Jul, 2006 at 10:18:23am
when my metro was running it seemed to have a problem when the turbo was spinning up.
3rd Jul, 2006 at 10:39:47am
how much boost are you running dude? have you blocked off the standard overboost valve in the plenum if you're running over 10psi or so?
3rd Jul, 2006 at 11:08:22am
i'm sure this will be the std valve as bud says.
3rd Jul, 2006 at 11:08:55am
ps, the only reason you get it in 3 and 4 and not 1st and 2nd is most likely due to you not really seeing full boost till 3rd gear. |
3rd Jul, 2006 at 02:47:48pm
even with the standard over boost spring thing it would still dump out the dump valve in all gears.
3rd Jul, 2006 at 02:51:06pm
could be lots of things. where do you live? some one here could have a look. |
3rd Jul, 2006 at 03:47:15pm
Im from OXFORD keep meaning to put it by my name, if sum one could have a look that wud be great cos ive come to a point i dont know what to look for.
3rd Jul, 2006 at 08:24:37pm
they will blow round the metal gasket i have had probs with mine in the past you just have to do them up bloody tight and put the tabs over. always looking for them bigger bunches of bannanas |
4th Jul, 2006 at 09:26:01am
still sound like the pipe from the air filter to the turbo sucking flat when on boost. seen it so many times. runs well but as it comes on boost there is a total loss of power. try it without the pipe but remember anything being sucked in hits the turbo thats spining at silly speeds causing massive damage. only run as a test.
4th Jul, 2006 at 10:31:54am
yeah i have been looking on mini sped and seen they do a reinforced gasket for injection and turbo's. im going to get one of them and just have one last go to see if it will blow. has allready desrtryed 3 standard gaskets. minispeed also sell the intake hose so i may aswell buy 1 of them too to elimanate the other prob. i will let u know how it goes.... |
5th Jul, 2006 at 09:03:45am
sorry if got the wrong gasget, the injection ones ive found the best always looking for them bigger bunches of bannanas |
5th Jul, 2006 at 07:10:00pm
I have always found that std metro turbo items work best for me, providing the surfaces are flat and the ports do not excede the metal reinforced rings |
20th Jul, 2006 at 06:09:50pm
a little update:
20th Jul, 2006 at 08:13:35pm
Keep at it buddy you will get there in the end.
26th Jul, 2006 at 01:01:57pm
hi people. the metro flew thru its MOT on monday without anything needing to be done. |
26th Jul, 2006 at 01:25:00pm
26th Jul, 2006 at 01:58:28pm
just a couple of things.
26th Jul, 2006 at 02:03:52pm
I had a similar problem with mine at Avon last year, it would boost in 1st and 2nd but nothing in 3rd and 4th!
26th Jul, 2006 at 02:11:34pm
Just thought are you still running that electronic boost control (cant think what the correct name for it is) Lol.
26th Jul, 2006 at 06:23:34pm
i am not running any type of electronic boost control (unless it is fitted as standard)
26th Jul, 2006 at 07:47:19pm
the metro came with an ECU to limit boost so as to save the gearbox.
