| Home > Help Needed / General Tech Chat > Need some advice with my map please | |||||||
3rd Jul, 2006 at 10:34:38pm
hi, ive managed to get the car driving now, ive basically modified the low MAP low Rev values of the TT map as mine was previously struggling to set off at all.
Edited by jamesfawcett on 3rd Jul, 2006. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
3rd Jul, 2006 at 10:37:44pm
RR no longer a series, but still 1.3 turbo.
3rd Jul, 2006 at 10:41:36pm
I have to drive it to the rolling road, and i wouldnt mind getting it running well before.
3rd Jul, 2006 at 10:43:57pm
is this one a bit clearer Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
3rd Jul, 2006 at 10:52:41pm
Also, for 8-9psi will i need to make the MAP go higher than 180? I dont really understand MAP yet Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
612 Posts Member #: 414 Post Whore Dalbeattie Scotland |
3rd Jul, 2006 at 10:53:06pm
Are you sure that your pully wheel and pickup are set in the right place can check by puting a timing light on and checking that when your map says for example 22 deg your engine is running at 22 deg mine was 10 deg out and fooled me for a while.
3rd Jul, 2006 at 10:58:12pm
hi allan its one of tom fentons so theres only one way to put it on i think
4th Jul, 2006 at 12:20:22am
the top spike is 0 degrees then each one down is 4 degrees dude.
4th Jul, 2006 at 07:48:03am
On 03/07/2006 22:52:41 feebleuk said:
Also, for 8-9psi will i need to make the MAP go higher than 180? I dont really understand MAP yet basically 100 is atmospheric, below 100 is lower pressure and above is higher (boost). to do the math(s) psi = KPa / 6.89476. To get the boost pressure that you are running (as this is boost pressure above atmoaspheric) you need to subtract the atmospheric from the answer, so: psi = (KPa - 100) / 6.89476. 180 is around 12psi Fastest 998 mini in the world? 13.05 1/4 mile 106mph
4th Jul, 2006 at 06:00:40pm
FUEL FUEL FUEL
AlexF |
4th Jul, 2006 at 06:17:53pm
fueling seems fine now, although rich most of the time. Ill do the 12 degrees thing and work out what bud666 suggested above Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
4th Jul, 2006 at 07:18:45pm
does the timing light with megajolt read double ? Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
4th Jul, 2006 at 09:31:54pm
mine read double,had it set on 8 cylinders no longer a series, but still 1.3 turbo.
4th Jul, 2006 at 10:09:53pm
On 04/07/2006 19:18:45 feebleuk said:
does the timing light with megajolt read double ? I dont think so. Allan |
4th Jul, 2006 at 11:09:00pm
cool yeah actually it read double, but also gave two flashes, one on the exhaust stroke i think too so 180 out.
doh
