| Home > Help Needed / General Tech Chat > the heater | |||||||
141 Posts Member #: 162 Advanced Member |
3rd Apr, 2004 at 12:58:16am
well as i have read in the past when converting a mini into a mini turbo after the bulck head mods the heater mounts are cut out. how did you guys get around this problem. |
3rd Apr, 2004 at 08:54:13pm
you could cut drill the spot welds off the old brackets b4 cutting the bulk head and tack them back on afterwards or make some new brackets once youve got your bulkhead box done it is simple to reattach your heater no longer a series, but still 1.3 turbo.
461 Posts Member #: 91 Senior Member Live @ Worksop, Work @ Rotherham |
5th Apr, 2004 at 02:04:55pm
I'm not putting mine back in cos it weighs to much, my mine isn't going to be an everyday car. |
5th Apr, 2004 at 05:38:01pm
mines an everyday car but i'm not putting the heater back in either, gonna put me head unit there instead i think. On 20th Oct, 2015 Tom Fenton said:
244 Posts Member #: 34 Senior Member |
5th Apr, 2004 at 09:11:22pm
If you take the heater apart, you can turn the matrix around 180 degrees. This makes the pipes exit towards the passenger side, and makes more room for your feet by the clutch pedal.
