| Home > Wanted > Ultralight flywheel wanted | |||||||
4th Jul, 2006 at 04:57:31pm
That's about it really. :)
4th Jul, 2006 at 05:06:02pm
Minits were the cheapest around if you cant get a good one S/H mate Crystal Sound Audio said:
![]() 6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
6th Jul, 2006 at 04:32:51pm
vegard, i have one i repaired by machining a verto centre into. the flywheel sits a little further into the housing so will need to space off the thrust bearing or bend clutch arm, i have removes some of the ringear so it does not catch the housing on the inner side because of it sitting further in, .this flywheel is almost like new, did just a few meetings at the strip before the fretting .it just needs bolts and nuts .which i dont have time to do and then the bolt heads facing off to keep below the friction face. got to be worth £60. ill get a pic this evening,
6th Jul, 2006 at 05:27:53pm
http://i24.photobucket.com/albums/c2/carl1964/DSCI0203.jpg Edited by fastcarl on 6th Jul, 2006. |
6th Jul, 2006 at 05:29:33pm
http://i24.photobucket.com/albums/c2/carl1964/DSCI0202.jpg.
7th Jul, 2006 at 09:39:27am
I'll have it Carl.
