Home > Help Needed / General Tech Chat > water cooled turbos
speedfreaq
Member #: 133
Jamaica
does anyone here run a water cooled turbo?
how do you run the water pipes? *oh well*
'I swear to use the Boost, The whole Boost'
'And nothing but the Boost..... So help me God'
I do, I run water from bottom hose, through turbo and then back into heater output on head, althought I dont think this is ideal
speedfreaq
Member #: 133
Jamaica
on the engine i have there is a little hose from the water pump to the head..........
i was thinking of plumbing the water lines there.
do you guys know how he direction of flow through this hose? :(
I think it goes from the water pump upto the head and through the block
The water pump draws cold water from the bottom of the radiator, into the block, then through the head and back into the radiator.
Phil. *smiley*
Jim do you find it puts extra strain on the engines coolent system?? or don't you notice the extra heat going into your water from the blower??
MW
I couldn't say to be honest mate, as I've never run with a t3 which has been setup correctly
hairy muff mate (sorry that's a Turbo Dave saying*wink*)
so is your water temp ok to keep down then jim?? as you have a side rad to don't you?
petterb
Member #: 75
Anyone knows where it is best to plumb in the turbo? anyone got any ideas? how is it when you plumb it in on the bottom hose? (where the heater normally is) does this mean that the water goes from the head trough the turbo into the bottom hose, and then get sucked trough the waterpump?
http://www.ktv.no/~pjb-ktv/
sorry matt, just seen your reply, to be honest mate, I've always had cooling problems
