Home > Wanted > flywheel housing
lil stu
Member #: 837
rugby
hi guys
ive been measuring the float on my the idler gear and its
0.023"!!!!!!!!!!!!!!
bit of a problem even if i used the thickest shims it still leaves me with 0.009"
i cant seem to find new ones anywhere
so any about?
cheers
Kean
Member #: 341
aka T2clubby
South Staffs
turbo or non?
andeh
Member #: 97
Near Daventry, midlands
try a different gasket first, these can be found for little money, infact if your stuck u can have one off me (std one not turbo as i dont have any)
Yes, mic up your gasket, you may find this is your problem.
Also do a search, there was a discussion about this subject at some point.
if all else fails would it not be easier to skim the face off the housing???
lil stu
Member #: 837
rugby
its a non turbo
i might have a go at skimming it sounds like a plan
cheers guys
lil stu
Member #: 837
rugby
just an update,
i faced the surface of the housing that was worn (around the idler gear) and then skimed the face of the housing.
its all shimed and seems fine,
thanks for the help
ttfn
