Home > Help Needed / General Tech Chat > gearbox differences???
Carl
Member #: 95
liverpool-on-sea
dug me spare gearbox out and inside looks the same but ive noticed a couple of slight differences.
No1= theres studs rather than bolts on the diff housing and transfere casing
No2= the casting around the idler bearing a bit different i think.
so i think that everything will still fit ok.
but will somebody that knows just clarify that it will or wont be ok.
cheers guys*smiley*
Earlier boxes had studs AND USED GASKETS
Later boxes used bolts AND NO GASKETS
Other than that they are all much of a muchness, as for the idler area, just check to make sure its an A+ box with the larger diameter idler bearing and not an A series which uses smaller idler bearings.
Do you mean gaskets or locktabs? I'm a bit confused as I've always used gaskets on everything
Ther is a generation of A+ box that has 4 bolts rather than 3 on the main bearing retainer (by the pinion). These tend to crack, I know I had one.
Wil
Tom means between the diff housing and maincase.
As a general rule - if there are studs, you need gaskets - if bolts, you need RTV.
However - in the 'changeover years' I believe there was an overlap period, so if you're unsure, then bolt it up and measure it to see if the area where the bearings sit is round or not.
Yes sorry, wasn't very clear there. Also the transfer gear case to the end of the block/box always uses a gasket AFAIK.
Carl
Member #: 95
liverpool-on-sea
Wil
yeah its got 4 bolts in the retainer. ill use and see how i go. thanx
Vizard advises against using a box with the 4 bolt retainer, and i was also told not to use one by Phil Hepworth {Gp A Turbo daddy}. I had one which i discarded on this advise and used a 3 bolt one.
Phil. *smiley*
Yep - if there are 4-bolts, put it on ebay...
Bah, I've only got 4 bolted ones, never a problem!
Well it's not a problem for low powered vehicles that get their ass whooped by milk floats / go peds....
Edited by turbodave16v on 7th Jul, 2006.
Lol ! *laughing*
Remote change all the way baby :)
Until today. Wouldn't you fucking believe it.
Apparently I have a high powered vehicle!! :)
Today when I was going to rebuild the box on BIR1 after a 3rd gear cone coating failure I saw that the casing was cracked.
Blimey, I don't have some half torque do I??
I guess it was bodged previously *wink*
Edited by Vegard on 20th Mar, 2008.
