Home > 998cc > 998 small bore BMW 16v options
Sir Yun
Member #: 1592
Smart Guy!
Hi all.
I'm still a bit at odds.
I can get a free 998 and convert it to a up to 1060cc. using a v16 bmw head i have, with the SC or MSPD bits you can get about 95-105 BHP without going overboad on longer duration cams and such. keeping the rev limit to about 7500..
trouble is I do have a bits for a 1330cc NA engine. st3 head RE13 cam the lot .. and that would probably make more power quite easily. I could fit the 16v head to the 1330 but I just dont feel like revving the pants of a 1275..
turboing a 1330..16v would probably just eat gearboxes (it does need to be able to drive 1000 km streches..and back).
what is more i could you build the 1330 as a NA engine and sell it build and get a faily decent amount of money for it.
Thus if i use a 1060 with the 16v and either supercharge or turbo charge it using only a modest amount of boost (if the original BMW K series engine is an indication. 3 to 8 lbs would be enough for me and push about 110 to 135 BHP)
now i am fully new to the whole practical side of the forced induction world and especialy turbo's.. i kinda get SC's but for turbo's the whole A/R and what not biz has me stumped a bit.
ther are a few ex cooper s SC about for near decent money. and you can get turbo chargers in two gazzilion variaties..doe anyone have a clue what units will be a good starting point.. note i would like the smallest unit available and just making big numbers is not really the point..
does anyone have deep thoughts on this subject.
if I was going todo another bmw convertion, I would only use one kit, and thats SC. Speaking from experience of dealing with both people involved.
put the 16v head on the 1330.
I have a bmw headed 1312 with turbo, runs awesome!
If you did supercharge it, It'd certainly be unique. Hopefully you'd put it above the exhaust manifold, or move the alternator back above the exhaust. It'd look a little ungainly (and probably not even fit in a clubman front end) if you tried it in front of the engine with that K1100 head being so wide...
EDIT - I just remembered, hasn't JohnK supercharged his 8v? Perhaps you should speak with him. :)
Edited by turbodave16v on 21st Aug, 2007.
I was under the impression that you could not fit the K1100 head to the small bore engine, but I stand to be corrected.
The Bini M45 supercharger would be a good choice on a 1060cc engine up to 15 psi boost. TD recently gave some good advice regarding supercharging an 1100 - same info would apply.
As for a turbo, the TT2 is using a GT1752 on a high revving 998 to give good results.
I would have thought a 1752 would be bit in your face for a road going 998, would a T2 or a GT15 be better? That said, no points for guessing what turbo I've got kicking around.
The TT2 is certainly making more nanas than alot of 1275 / 1293 turbos.
Edited by Rob H on 21st Aug, 2007.
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
Ah that australian fella who has just joined is using a old mr2 charger. These powered 1600's. Compact. might be a good shout on this engine.
Radleigh
Member #: 1643
West London
Im being dumb, But who are 'SC'
Im looking into this kit as an option, As Im after more power!
cheers Radleigh *happy*
johnK
Member #: 690
Norfolk
Radleigh - I am Specialist Components (commonly called SC at times) - though in this thread I think SC is being reffered to as "supercharger" (apart from Jims comments!)
visit www.specialist-components.co.uk for info on kits.
cheers
Johnk
If Carling made Mini engines
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Specialist Components (JohnK on here)
http://www.specialist-components.co.uk/
To parts, nice people to deal with and good pricing too ..... don't forget to mention TM when ordering!
Sir Yun
Member #: 1592
Smart Guy!
I have looked at a rotrex unit (which is about the size of an alternator and is basically a mechanically driven 1/2 turbo) but after inquiring about the price i was a little less enthousiastic. : (
I suppose a m45 would be fittable with the right manifold but it is a bit large. I doubt i could find the MR charger over here. to the best of my knowledge they where never imported here.
the turbo manifold would be quite a challenge i think,
Jimster do you have pics on how you solved that one ?
Can anyone confirm that you can fit the K1100 head on a 998?
I thought the valve spacing meant that they hit the block.
Dave,
Somone posted on TMF a little while back that Morspeed had a Scharged a 16v, there were pics on the website but they've now pulled them, I imagine it was just a showpeice, I also think it looks stupid.... also how little wrap around is there on the alternator pulley...
edited with extra pics
Edited by Joe C on 22nd Aug, 2007.
Right, I've looked into this a bit further.
You CANNOT fit a K1100 head to a small bore engine due to the different cylinder spacing.
This is my 998:
Note the large gap between cylinders 2 & 3.
The K1100 has relatively equal bore spacing as does the 1275.
EDIT: You can fit the K100 8v head - see below
Edited by Paul S on 22nd Aug, 2007.
On 22nd of Aug, 2007 at 11:39am mini13 said:
Dave,
LOL another classic case of shooting yourself in the foot by Morespeed. How is that ever going to fit in a mini.
Also notice the supercharger belt is at least 25mm wide but it's running over the std waterpump pulley.
Has anyone ever seen one of Morespeds engines running yet? (in a car)
RogerM
Member #: 1217
OMG .....
If that was the first I'd seen of Simons work it'd put me off dealling with him forever!
RogerM
Member #: 1217
Axle, the first K head conversion I saw was on an 850 and there were links too it on one of the original K head threads IIRC.
Ive also heard that 998 spacing is wrong for the K head. 850, 1275 are the only options!
Lol...I did think when I saw that pic that it would stick out a fare amount! *laughing*
Didn't noticed the alternator pulley or water pump pulley!
Here's the link. *wink*
http://www.miniman.com.au/bmw.htm
johnK
Member #: 690
Norfolk
sorry - late in replying - the answer is yes you can fit a 16v head but with lots of cut outs in your block! - so not an option in reality. The 8v will fit due to only having to clear one valve on the piston edges. Don't under estiamte this head folks - especially in turbo form!
- had an email from Greg (the first one to do the conversion) the other day - nice chap, his engine was an 850 + 8v head for reference
cheers
JK
- on superchargers - I am still looking at doing a charged engine (the bottom end hardware is there), wether it be super or turbo I'm not sure yet - but it will be a front mounted Eaton - not a bini one and it will fit under the bonnet of a round nose mini!!!!
Radleigh
Member #: 1643
West London
Ahh, Yeah sorry! I do know.. A friend of a friend actually just brought your kit! From heathrow way, if that means anything to you?
Had a nose around the site a few times, Just "SC" didn't click lol
thanks *happy*
cheers
Johnk
Sir Yun
Member #: 1592
Smart Guy!
uuhm.
had not physically checked the 998 I more or less assumed it would fit as it does fit an 850..but failed to notice that was the 2V version
I could go and hunt for a 2V head, but
darn I'll just have learn how to live with excessive 1330 power then.
Jimster do you have pics of your turbo install ?? does it not generate too much power? (what am i saying...)
as for the pictured charger setup..
hmmmm.
I did not notice the water pump pully.. good eye
238 nanas I seem to recall from the weekend..lol
....So not too much *laughing*
Click on the link on Jims post. *wink*
Hang on a sec - in Morspeed's defence (!) I don't think this particular example was engineerered to fit in a mini. It looks like the coil pack is mounted where an inner wing would ideally be?
I know its on a mini gearbox, but maybe it's for a midas or some other kit car?
miniminor63
Member #: 672
The oversills police
Oslo, Norway
I did see that also, but still, the water pump pulley....NOT good. It may also have been thrown together as a display engine.
ok - I'll give you that!
A disply engine should look a little better. Maybe no internals - but the externals should be spot on (IMO). That said - I've never assembled a K1100 head onto an A-series.
In every mini based kit car I've seen there is a bulkhead where that blower sits.
Had a good look at that GTM at the Pod on Sunday. Daily drive. Running 12s on a 1.8vtec.
