Home > Help Needed / General Tech Chat > crank tuftriding
turbo22
Member #: 3684
wisborough green west sussex
my crank has been lightened and balanced but is it worth hardeding it as well as i will be running between 160-200bhp cant find anyting on this on the search!
Forget tufriding, think nitriding.
Worth it if you plan to rev the knackers off it, say over 7k.
Or if you have a spare bit of cash it won't hurt. I pai'd £25 + vat to have mine done iirc. (8 years ago at bodycote in Stockport)
whats the difference wil
litterally the name, tuftriding is an ICI registered process, if i'm not mistaken, , nitrocarburising is the more common term,
turbo22
Member #: 3684
so it only costs roughly £30 to get done and its worth doing if you are going to stress your end?
Nitriding is not nitrocarbonising.
Nitriding is a heat treatment in a controlled atmosphere, the others are chemical processes.
Well it only cost me £30 ish, but it was few years ago. Also, after the process you need the journels polishing, which will be a small cost.
You can only nitride EN40B cranks as far as I know.
slater
Member #: 1291
Suffolk / Birmingham
yeh, you cant 'nitride' a cast crank can you?
I have had several done as for £30 it seems liek good insurance, Its basicly to increse wear resitance is it not? so its a 'spend £30 now, dont spend £30 later' kind of deal
Cast?
slater
Member #: 1291
yeh cast, as in iron, not steel, cast not forged/billet
We I had it done to a standard 998 crank.
do you know for sure it was Nitrided . or is it possible the place you took it too just either Tuftrided or Nitrocarburised , i was also told by the firm that carry out my Tufdriding that only illustrious steels can ne Nitrided.
carl
It was deffo a heat process not a chemical process
I'm pretty sure that you will find that all A/A+ cranks are made from forged steel not cast.
Most are forged EN16T.
EDIT: Found this:
Interestingly, he claims that the Metro Turbo crank was a SG Iron casting.
Edited by Paul S on 14th Feb, 2009.
h4887
Member #: 2404
Braintree, Essex
Actually Tuftriding is a higher-temperature process than nitriding, as it involves immersing the part in a bath of molten cyanide. Mmm, tasty!
Geoff
slater
Member #: 1291
nitriding is a chemical process tho too isnt it? they just bung ammonia in the furnace as a gas so it diffuses into the metal and forms nitrates with the verious alloy elements in the steel. Tuftriding is a simlar thing but with sodium cyanide in a liquid bath? the advantage of the nitriding being the lower tempretures involved dont warp the crank like sometimes happens with tuftriding and the hard layer produced is thicker with the nitriding.
thats about as far as my knowlage goes.
which is as good an explaination as iut gets and we need,
carl
h4887
Member #: 2404
Braintree, Essex
Sure you don't want any more on nitriding? I'd hate to think Essex Education Authority wasted their money when they paid for me to get a BSc in chemistry *Nerd*
Geoff
hello! local boy eh?
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I'm surprised Essex Council can afford to pay for anything!
On 19th Jan, 2010 wil_h said:
PMSL!!!!
damn straight, the can fix the effing roads for starters! maybe because most councels in essex stuffed their money in iceland banks....
not ot mention bazildrain councel haviing a masive overhaul costing 2 million on their offices, despite them being due for demolishment in 5 years...
grrrrrrr.
h4887
Member #: 2404
Braintree, Essex
It was a long time ago!
Geoff
so its nitriding the chaps.....lol
What is ni-tempering. Google hasn't turned much up.
Is it just some of the speed shops term for tuftriding or is it a different process?
Nitride tempering.
http://en.wikipedia.org/wiki/Case_hardening
