| Home > General Chat > A series rather than A+ | |||||||
603 Posts Member #: 1938 Post Whore near Dundee |
21st Sep, 2009 at 07:59:06pm
right i plan to turbo my mini and have got myself a 1275 A series engine, now i plan to run megajolt or similar to get over the problem of the distributer out of the metro turbo not fitting. ( i know you can modify the shaft but its not something i want to do myself)
21st Sep, 2009 at 08:00:58pm
not really,
21st Sep, 2009 at 09:20:11pm
Don't forget the drop gears and transfer case need to be for an a series engine. They A+ are different On 11th Feb, 2015 robert said:
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
21st Sep, 2009 at 09:28:21pm
will there be any issues in the oil pump dept, or the the timing chain? |
23rd Sep, 2009 at 10:06:19pm
the timing chain on mine is alreay a duplex as standard so should not be a problem.
23rd Sep, 2009 at 10:26:40pm
none of the above except for alternator bracket is valid.
23rd Sep, 2009 at 10:47:53pm
while on the subject of gears what gearkit can i fit?
24th Sep, 2009 at 07:54:35am
On 23rd Sep, 2009 miniminor63 said:
Oil pump is the same The oil pumps do differ, the A+ have slot drive and the pre A+ have a star drive. Unless they have been changed along with the cam.... Edited by apbellamy on 24th Sep, 2009. On 11th Feb, 2015 robert said:
24th Sep, 2009 at 07:59:55am
okay then, oil pump fitment is no problem. :) |
24th Sep, 2009 at 09:44:03am
Ive seen people machine the mains to accept the A+ turbo shells which is a nice touch
I seriously doubt it! |
24th Sep, 2009 at 10:02:59am
On 24th Sep, 2009 paul wiginton said:
Ive seen people machine the mains to accept the A+ turbo shells which is a nice touch Paul one of the simpliest jobs to do too, carl |
24th Sep, 2009 at 11:04:59am
I've also seen people machine the mains on A+ blocks to fit proper bearings... On 13th Jul, 2012 Ben H said:
24th Sep, 2009 at 11:14:33am
?? Proper bearings?
On 24th Sep, 2009 Vegard said:
I've also seen people machine the mains on A+ blocks to fit proper bearings... If something is worth doing, it's worth doing half of. |
24th Sep, 2009 at 11:30:28am
Yes, not the junk A+ ones.
On 24th Sep, 2009 minimadmotorman said:
?? Proper bearings? On 24th Sep, 2009 Vegard said: I've also seen people machine the mains on A+ blocks to fit proper bearings... On 13th Jul, 2012 Ben H said:
24th Sep, 2009 at 11:39:11am
Ok V I'll bite.
24th Sep, 2009 at 12:28:02pm
Ok V I'll bite. What do you class as a proper bearing? Something that lubricates the entire main journal, and doesn't starve the big ends of oil 50% of the time. Not such a big problem on a standard Metro (This has been proven for 25 years) but not was good when you're racing, or turning big rpm. On 13th Jul, 2012 Ben H said:
24th Sep, 2009 at 07:29:48pm
Ive seen people machine the mains to accept the A+ turbo shells which is a nice touch Paul one of the simpliest jobs to do too, carl ive searched but cant find a picture. is this just machining out a groove in a different posistion for the tab or am i missing something Edited by Adam_R on 24th Sep, 2009. |
24th Sep, 2009 at 07:33:23pm
yep thats right, just the tab,
24th Sep, 2009 at 07:39:45pm
On 24th Sep, 2009 mini13 said:
yep thats right, just the tab, you can do it with a file of your carefull, or a dremel with a grinding disc and a steady hand works well. are the turbo bearings a heavy duty bearing then? i guess it would be beneficial to get my crank cross drilled and tuftrided while its in for a grind? |
25th Sep, 2009 at 09:34:46am
Have the mains crossdrilled as well, if using the A+ bearings and high revs. On 13th Jul, 2012 Ben H said:
25th Sep, 2009 at 09:43:33am
Come on then V, you have me intrigued. What is the problem with A+ shells? why do they starve oil flow? and do you have pics of crossdrilling the mains?
Edited by paul wiginton on 25th Sep, 2009. I seriously doubt it! |
25th Sep, 2009 at 10:34:11am
It's all in here.
Edited by Rod S on 25th Sep, 2009. Schrödinger's cat - so which one am I ??? |
25th Sep, 2009 at 12:09:29pm
The turbo cranks aren't cross drilled either. I've never seen a factory cross drilled A+ crank. On 13th Jul, 2012 Ben H said:
25th Sep, 2009 at 12:15:59pm
Rod i thought Vegard was the post excavator? If something is worth doing, it's worth doing half of. |
25th Sep, 2009 at 12:25:30pm
Thats an interesting read, never heard any of that before. I run turbo shells and crank but dont have a clue if its through drilled or not, though I will check on this when its out next.
